When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me. Last, check your input setting to pop the tv set back over to where it used to be.
my unit has attached sky box with an any time plus box and sound is through a yamaha tuner 5.1 system. i cannot pick up any freeview on the tv and get this same error. whenever i tried a system reset i was told there there was no signal on this network and the error was as above E202. it will show any sjky but nothing on the built in freeview
