Microsoft Windows XP Professional for PC Logo
Posted on Jan 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, befor i install window 7 my laptop running window vista now istall window 7 geniune 7600 build i want update update driver but show the screen victim of software counterfeiter please help me how to solve the problem
bridges_dian
Level 2:
  • Expert 37 Answers
  • Posted on Jan 02, 2011
bridges_dian
Expert
Level 2:
Answers
37
Questions
0
Helped
26183
Points
108
Buy the license first.
Download Key Update Tool, a utility provided by Microsoft to change the key of the Windows version installed.
The download address is http://go.microsoft.com/fwlink/?LinkId=50346&clcid=0x409
Double-click the utility will then check the system files.
Enter the official key and click Next.
Accept the license agreement and click Next.
The key is legalized.
Click Finish.
Windows restarts.
2answers
Remove wat could not solve my window is not genuine build 7600 problem give me another aolution
Windows 7 Build 7600 by default will not allow you to do an upgrade install.
This how to will describe the process needed to upgrade from Windows 7 Build 7100 to Windows 7 Build 7600 with out doing a clean install.
Download the ISO as you did previously and burn the ISO to a DVD.
Copy the whole image to a storage location you wish to run the upgrade from (a bootable flash drive or a directory on any partition on the machine running the pre-release build).
Open the file cversion.ini in a text editor like Notepad
Modify the MinClient build number to a value of 7100.0
Save the file in place with the same name
Run setup like you would normally from this modified copy of the image and the version check will be bypassed.
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB.
You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
http://100-downloads.com/publisher.php?pb=http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool&dl=727
http://download.cnet.com/windows-7-usb-dvd/3000-18513_4-10972600.html
Create a copy of your Windows 7 ISO file on removable media
3answers
Windows 7 build 7600 This copy of Windows is not genuine,
Try this program:http://www.softpedia.com/get/Tweak/Unins... and disable automatic updates: START-> CONTROL PANEL-> AUTOMATIC UPDATES -> CHOOSE THE OPTION -> Turn off automatic updates <- ;-)
2answers
Its common display driver problem i think. it fails with blue screen right before windows boot up. some say its because of overheat problem and other says its out-dated driver . windows 7 can boot up in...
try to open safe mode through F8 key
there r two solution's:
(1) Might be windows is corrupted that's why it shows blue screen before startup. Take ur data backup and reinstall ur OS.
(2) It's might be there is some issue with ur RAM. Remove ur RAM n gently n clean ur RAM with pencil eresar. Then reinstall it.
I have ibm Thinkpad R52 notebook computer, when i instealed window 7 after that sound device is not working.
Go to this page:
http://www-307.ibm.com/pc/support/site.wss/MIGR-58931.html
When it loads up click on where it says audio near the top of the page and it will bring you down to the audio driver section.
In that section it shows you that anything more then windows XP and you need to run windows update to get that sound driver installed. Vista drivers will run on Windows 7. Windows 7 was made from the Windows vista source code which is why the drivers will work.
Click on Start and then All Programs, you'll see where it says windows update. Go ahead and click on it and then click on check for updates. It may ask you to enable updates. If it does then click on the button that says Turn on Automatic Updates. Windows will find the driver and it will install it for you.
I have Windows 7 Build 7600. My Gateway NV5814 laptop doesn't connect to the internate post a windows update. The Ethernet cable is plugged into the NIC port but the blue and green lights do not blink and...
hi
Please disable windows update. Click on start , click on run type services.msc and click ok locate windows update , double click on it , click on stop and change the startup type as disabled . Click on apply and reboot .
I installed windows 7 ultimate build 7600 and it download a generic video driver but the resolution is not the same it doesn't look very well
Easiest thing to try first is a Windows Update, check the optional downloads section to see if Windows was able to find an updated driver.
Let me know if that works.
Hi, i just installed window 7 on this model sony laptop nr220e. before i was using the default vista and my webcam work fine now after i install window 7, i try to open webcam in yahoo messanger and it...
It is a DRIVER issue. You DO NOT have the right driver for your webcam and Win7. Try the XP Drivers. Here is how to Install them so they work. Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all
1helpful
5answers
I have installed windows 7 on my acer aspire 4736. The thing is, whenever I lower down or push up the volume on my laptop, no icons for the volume can be seen on the screen. also when i switch on/off my...
I had a similar problem when my driver wasn't installed. Go to the manufactures website and find the soundcard driver for windows 7. If you cant find the soundcard driver designed for windows 7 try downloading the vista one
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
