SOURCE: User Manual required (Kelvinator Washing Machine)
Click on Bosch or your brand (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
SOURCE: need to replace carbon brushes on Indesit Omega 1200
The brushes are located inside the motor. Remove rear panel of washer, remove drive belt, from motor and drum, unplug the motor, undo screws that secure motor, and remove motor.
At the opposite end to the motor pulley, you will find the brushes located, undo 2 screws that secure the brushes, remove and replace brushes.
I would also check the pump filter, which should be located behind a removable panel at bottom of washer, unscrew anti-clockwise, remove and clean.
Please rate my fixya solution.
Thanks.
SOURCE: I require a user manual for a Whirlpool AWG5122
if you go to the whirlpool web site under support you should be able to download one.
SOURCE: indesit 1200 washing machine boils everything and
make sure you have connected the cold water feed and not a hot water supply, these machines need a cold water feed only
