Ive been given an Indesit WIL133 washing machine but all the buttons are very confusing without a manual...can I get one anywhere
Please check on this link: manuals
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
SOURCE: indesit we14
Hi l have a indesir WIE147 that keeps on flashing F 01 repair man came changed module and next day same thing happened again HELP PLEASE
SOURCE: code error f07 indesit washihg machine
Per Maytag, they suggest you unplug the washer for 20 minutes and see if that resets the circuit board.
SOURCE: f-02 fault code on indesit we16 washing machine
For what it is worth my WE16 often stops with an F-02 display within 3 minutes of starting, but only in summer months. Powering off and restarting usually cures it, and it will then go on to run several loads without problem. I keep the machine in my cellar boiler room, and attribute the problem to high humidity when the boiler is not running. Changing the PCB does not cure the problem, nor does protecting it against humidity (eg poly bad and silica gel). I conclude that moisture getting somewhere unexpected (tacho perhaps?) can cause this error.
