Well I don't know whether you have been to that specific printers hP support page for manual two sided printing. please click here and check it out as it may assist solve your problem.
regards
thanks for appreciating, please check out this video demo ( its not exactly for your printer) but it will give you guide on the printer driver setting.
regards
Hello Jeff,
When you say you want to print duplex manually, I assume you are simply trying to print double-sided pages. I am going to propose an option that may seem too obvious, so forgive me if you have already checked this. If this does not work, please get back to me, as I work with HP authorized printer technicians and I have access to support options not available to the general public.
Anyhow, regardless of the settings in the printer options (control panel - printers) and in the print dialog box (options you can select after cliking print). I need you to check something very basic. Your printer came from the factory with 2-sided printing turned off by default. I want you to turn it on using the control panel of the printer. Please follow the steps below, and kindly reply and let me know if this helps. If not, I can help more.
Regards,
Joe
Reinstall the driver ..and I recommend to download the latest driver from the support site and not from the disk cause it may be outdated..
here is the support site ...If the issue is a software one ..this will fix the problem ..
If by manually you mean manually fed this may not be possible for this printer ..and only the auto 2 sided to work ..
http://h10025.www1.hp.com/ewfrf/wc/pfinder?tmp_product=hp+3000n&tmp_qt=&submit.x=0&submit.y=0&cc=us&lc=en&dlc=en&product=&tmp_searchExperience=0
Note The information in the Properties dialog box varies depending upon the manufacturer of the printer you're using. With some printers, you will see a Layout tab with a Print on both sides option on it. With other printers, you might see a Features tab, and the duplex option might be called something like Two-sided printing. Explore the various tabs in the Properties dialog box until you locate the duplex printing option.
The options will be called something like Long edge (or Flip on long edge) and Short edge (or Flip on short edge). Whether it's better for the paper to be flipped on the short edge or the long edge depends upon the type of publication you're printing. You might need to print a test publication or two to discover which option works best.
I've installed the new driver, but it made no difference. If manual feed duplex printing is not possible on this printer, then hp are keeping it a secret:
http://h20000.www2.hp.com/bizsupport/Tec...
Previous 'expert' offered nothing beyond the obvious, which was quite useless. Can you do any better than this?
Thanks, I think a solution is close. On that page you linked me to, it says to 'open the printer driver'. How do I do that? If it means open System Preferences > Print&Fax > Options&Supplies > Drivers, then there is no 'Finishing' tab. Regards
Solution was very helpful, thanks.
