Sc 322 is laser synchronization error Possible Cause : 1- Poor connection between the LD unit and the BICU board 2-Damaged cable between BICU and LD unit 3-LD unit out of position 4-LD unit defective 5-BICU board defective the first thing u can do is clean the laser unit , it could be dirty
sc220 means laser synchronizing detector board, (used to determine the start timing of laser writing), does not send asignal while the polygon motor operates normally and the LD mirror in laser may be stink clean it carfully and clean small board synchro which detect invisible laser beam
sc 305 means pcr primary charge roller did'nt work correctly that means did't give sufficient charge to drum unit possible causes pcr defective
sometimes
the plastic of the laser is turned by the heat proves to relax and to fit the
screw that holds the laser unit that is of the side of the drum while it raises
a millimeter with a screwdriver, this sometimes works. Verifies that theglasses and mirrors well
be positioned correctly. Other
Poor connection between the laser synchronization detector board and the LD unit. Laser synchronization detector board out of position Laser synchronization detector board defective LD unit defective
