Ricoh Aficio 1035 Copier Logo
irfan ali Posted on May 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ricoh 1035 laser problem
Hi sir i have problem in ricoh 1035 machine in laser its give code sc 322 and some time sc 326 first code 322 is 1st laser synchronization error i change it its same problem even i change 2nd laser synchronization its still same sir tell me in laser whats parts problem send me detail plz. thanks
Anonymous
Level 2:
  • Expert 162 Answers
  • Posted on Nov 15, 2009
Anonymous
Expert
Level 2:
Answers
162
Questions
Helped
131000
Points
285
Sometimes the plastic of the laser is turned by the heat proves to relax and to fit the screw that holds the laser unit that is of the side of the drum while it raises a millimeter with a screwdriver, this sometimes works.
Verifies that the glasses and mirrors well be positioned correctly.
Other
Poor connection between the laser
synchronization detector board and
the LD unit.
Laser synchronization detector board
out of position
defective
LD unit defective
  • Behzad Rezaei Jul 13, 2014
    yes its true, often you can fix that with clean miror's and LD board,
Mohamed Gaber
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Dec 25, 2016
Mohamed Gaber
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
15866
Points
48
THIS VIDEO SHOW HOW FIX IT
https://youtu.be/-DGnULMHtD4
Bernard D'Souza
Level 2:
  • Expert 165 Answers
  • Posted on May 08, 2009
Bernard D'Souza
Expert
Level 2:
Answers
165
Questions
0
Helped
103448
Points
253
Check in sp mode - history if there any more errors.
are there any humming sound?
check the polygon motor if it turns properly.
try cleaning all the mirrors.
check the cable (ribbon)
2helpful
Error code sc 322 for aficio ricoh 2045
this is a laser unit problem.check laser connections clean the laser unit.
How i can solve the ricoh 350 error sc-322
hii dear 322 means synchro1 not detected signal that go to sp mode yellow cancel and put 107 and hold on red cancel 3 seconds yo will see copy sp in asquar then put 2109and# and 2108and# and close machine and open if it's not work out try to clean mirrors in laser unit ok
6helpful
2answers
Sir my Ricoh 1045 machine have SC 326 problem, after taking a single copy the error code comes. please give a good solution to clear my problem. thanks
sc326 is a laser synchronization error. The problem is usually caused by the laser sync detection board or the LD unit.
3helpful
Please solve this problem Ricoh 7650 Code SC 902, 302 and 322
SC322: Laser Synchronization Error
Definition [B’]
The laser synchronization signal cannot be detected from the synchronization
detector even if the laser diodes are activated.
Possible Causes
• Poor connection between the laser synchronization detector and the LDB
• Laser synchronization detector out of position
• Laser synchronization detector defective
• LDB defective
• SICU defective
• Front door safety switches defective
SC302: Charge corona output error 1
SC902: counter error
2helpful
2answers
I HAVE AN ERROR SC 322 WHEN i GO TO PRINT RICOH 1035
Error Code SC322:
The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Possible Causes:
+ Poor I/F harness connection between the laser synchronization detector board and the LD unit.
+ Laser synchronization detector board out of position and angle of reflection not correct
+ Laser synchronization detector board defective LD unit defective
Not sure what your expertise is on this, but unless you know how to service the machine yourself, this one is going to require a service call...
There have been instances where toner drops onto the LD Unit and creates problems like this. About a month ago I replaced the Laser Synch. Detector Board in a 1045 for this exact problem and error code.
I'd start by cleaning up any toner on the LD unit, and re-seating all the electrical connectors on the laser unit. If that doesn't clear things up, it's probably one of two things, the LD Unit or the Synch. Board. I'd lean more towards the Synch. Board myself, but you never know...
1helpful
2answers
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
6helpful
3answers
Sc 322, sc 326 codes
Never heard of this happening to five machines before.  Check the connections in the laser unit.
2answers
Aficio 450
SC 322 is a laser diode problem. It will require service.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
