Try again! Remove the paper from the rear tray. Turn off the printer. Load the tray again making sure that it pressed frimly in and not over loaded - say about 30 sheets. Turn printer on again and see if it is ok. If still the same problem, get in touch with supplier or maker.
PIXMA Pro 9500 MKII Error B200 = VH (Print Head Drive Voltage) is out of the specified value.
Need to :
- Replace print head and logic board at the same time.
or
- Replace Carriage Unit
or
- Power Supply Unit
The photo paper is a little stiffer than bond, you usually just need to clean the feed roller with a damp rag to restore grip. When it ejects like that it usually means the paper is getting in too late due to slippage of the feed roller.
This is a good printer, if the paper is blank you may need a purge assembly, if there are 11 blinks of the error light it just needs Canon special lube for the paper transport. Definitely worth the repair...
