-please clarify. do you mean SSD?
-if yes, you can buy an SSD kit from known vendors like Western Digital of Segate or from any computer accessory retail store.
-you may need small philips head screw driver to open the hard drive compartment.
-NOTE: make sure that you are not voiding the hardware warranty of your laptop when you do this.
-choose the capacity that you need and it comes with instruction how to use the kit.
-normally what you will do is, you plug an external USB to SATA adapter onto the computer, plug the SSD on the other end. Install the software that comes with it, use the software to kinda clone the content of the built in drive to the SSD drive. After the clone process is done, you need to turn off the laptop, unplug the AC adapter, remove the battery pack, remove the hard drive that came with the laptop, put in the SSD, put back the battery pack, plug the AC adapter back in, then turn the computer on to test the SSD.
