We are having dlink router. wireless ssid is not showing in some of the laptops and mobile; eg. showing in Apple phone and not showing in htc, showing in sony vaio not showing in hp pavilion g6 laptop.
The D-Link wireless router may have the SSID broadcast turned off.
In this case only computers that have wireless connection to the D-Link will show the SSID.
If you know the SSID you can enter the SSID manually in the wireless card settings in the laptop/computer.
OR
Turn on SSID broadcast in the D-Link wireless settings.
SOURCE: di-524 dlink; wireless laptop connects but no internet or network
Your wireless card is dead, replace.
SOURCE: Can't print using HP C6180 Printer via DG834G router
I helped a friend with this problem. He had Vista and was running through a Linksys router. You could see the printer, access the webserver through Internet Explorer by browsing to the IP (192.168.1.X), but the print job would hang, but would kick off immediateley if you reboot, but after it came up and printed that one job, it wouldn't print again. Here is the fix:
Find the IP of the printer and the exact name, which you should be able to get from browsing in Internet explorer to the IP. I think its under the farthest left tab and the 2nd option on the sidebar. I renamed it to HPC6180 because the original name was something like HP92601345U.
Now right click on the start button and click properties and select Classic Start Menu and click Apply/OK. (You can change this back later)
Click on the start button again and click Run and type in "drivers". When that folder opens up, go into the "etc" folder.
Right click on the file named "hosts" and click properties and uncheck "Read Only"
Then double click on the "hosts" file and open it in notepad.
Go down to the first line that isn't commented, it should say something like 127.0.0.1. Position your cursor on that line and hit enter to move 127.0.0.1 down one row. Then enter the IP address of your printer. Space over and line up with the entry below and add the Host Name (mine was HPC6180).
Click file and Save As, and in the file type, change it from .txt to "All files" and click ok, and click OK to overwrite existing file.
Close all your windows and reboot and try to print again. It should work now.
SOURCE: Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
SOURCE: ps3 keeps cutting out wireless internet
You may have an IP conflict. Renew the IP on both the Sonys
At a command prompt,
ipconfig /release
it will come back with all zeros
ipconfig /renew
It should pick up a new IP address.
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the router.
Frequent wireless disconnection can be caused by different factors such as:
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
Customizing Wireless Settings of the Router
Having default wireless settings on the router may cause conflict with other routers within your network range. Recommend changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Can't obtain IP - Net Gear WNR2000 router
Try to open the Router page using "ROUTERLOGIN.COM" in IE and go to WAN Setup option in which u can see Disable SPI Firewall (check the box), also reduce the MTU Size to 1400 or 1390
