SOURCE: Citroen C15 Diesel Van.
It definitely sounds like the electrical part of your ignition isn't working properly.When you turn the key, the lck and tumbler turns on the ign. switch in which sends power to the rest of the car.
SOURCE: blower fan
it sounds to me like your blower moter resister or your blower moter switch are going bad both are right under the hood next to the blower moter one has 2 witers on it the other has 4 it usuley on the pass side right near the window
SOURCE: Car alarm won't reset after disconnecting car battery
you should try to hit the unlock button on the remotes and that should disarm it. Try disarming that, that way and if that doesnt work we will go from there
SOURCE: My Mustang Cobra has a Viper alarm system that won't set
Under the dash, Your installer that worked on your Cobra should have put an valet button under the dash, It is a small round Black button, Ok with the driver door open,,put your key in the ignition and go to the on position, Locate the black button before you do this, once the ignition is on hold the black button down for 3 seconds hit it once more and then turn the ignition off, the light should start flashing again and the chirp for arm and disarm with work again, What you have going on is called Valet mode which is designed to put the alarm side of the system to sleep which can happen from accidentally bumping it.
Hope this was helpful.
That Crazy Install Guy.
