5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
Posted on Jan 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Disable viper alarm
I have a viper security alarm in my 1994 firebird, it was already installed when i bought the car, has no remote, and i know nothing about it, when i changed the battery, the alarm keeps going off and the car will not start , everything is shut down, how do i fix this, or simply disarm this alarm?? someone please help me, i miss driveing my car
Anonymous
Level 2:
  • Expert 171 Answers
  • Posted on Jan 08, 2010
Anonymous
Expert
Level 2:
Answers
171
Questions
0
Helped
85376
Points
387
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
John martin
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 01, 2016
John martin
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11158
Points
Lock the car
Place key in door unlock the drivers door
Open it and shut it lock car
Press the unlocked 2 times
Open all the doors starting with the drivers
Then close all the doors starting with the passenger door
Lock car
Unlock
Place key in ignition
Don't start it wait 5 mins
Turn it off then try to start
How do I disable the alarm to start my vehicle I can't find the kill button.
https://www.google.com/search?q=old+viper+alarm+disable+alarm
Viper Support Center - I need to temporarily override my alarm ...
Viper - Car Alarms https://www.viper.com > support > guideTitle=I-need-t...
This method has you open the driver door, then press the lock button, immediately followed by the unlock button, immediately followed by the lock button again.
Missing: old ‎' Must include: old
How to Disable a Viper Car Alarm - It Still Runs
It Still Runs https://itstillruns.com > disable-viper-car-alarm-7494080
Press and hold the "Arm" button on your remote until the alarm turns off wirelessly. Step 2. Open your car door, and use the "remote valet" method to stop the ...
How do I program my viper replacement transmitter for my car.
Dear Marta,
Here is a hands on to watch and program as you go. Follow to the link. How To program DEI Viper Python Avital Sidewinder Valet Hornet Alarm...
Here is another look. 1f Responder LE Remote Pairing
For your direct contact to Viper follow this link for any question. Viper Support
Fare. Well.
How do i use remote start. i just bought a van and it has a viper remote
That alarm system you listed, the Viper 650XV does not have remote start capability. It's just a basic alarm system.
Just bought a`used truck that came with a Viper RPN 479VPC remote. Is this just a car alarm or is this a remote start also? Any help? Little blue remote with car diagram on screen...has lock, unlock, aux,...
That remote can work with both a security system, and a combo unit security/starter.
Best bet is to take the vehicle and remote to your local Viper dealer and they can look the car over and tell you what was installed and help you learn how to use it.
I received two of these systems in the mail and I am going to attempt to install it myself. I have been reading up and wanted to know if there are any detailed install instructions that I can find....
Not sure if you have this already, but here's a link to the wiring diagram for your vehicle: http://www.modifiedlife.com/2003-buick-rendezvous-remote-starter-wire-diagram/
Notice: All Viper Car Alarm Systems, Remote Starters and Keyless Entry Systems Require DEI Professional Installation for Warranty!! I'm sure you already have the owner's manual, but here's a link to Viper's http://www.viper.com/Support/ Last but not least... this is what I found online in regards to installing your Viper 5701 2-way Alarm w/ remote start: http://forums.evolutionm.net/evo-audio-security/364122-diy-viper-5701-install-ct9a.html
Hope some or all of this helps you!
1helpful
So I have a viper alarm system in my car and awhile ago the remote got wet, so in order to be able to start my car i had to disable the alarm by turning the ignition on and pressing that eraser like...
You have to turn off your ignition and immediately press that 'eraser like button'(valet switch) for a second and release it. Alarm will then come out of valet mode and your remote should work, if it's good.
2helpful
2answers
Lost my Viper key fob alarm is on and cannot start truck. any solution to disable?
Your alarm should have a button that was installed called a valet. What you want to do is put your key in the ignition turn it to the on position (Don't start it) then with the car in the on position hold down the valet button until the led light on the alarm goes solid and you should here the alarm beep twice. now your alarm will be disabled. To reable the alarm do the same thing.
I lost my remote for my viper 350 hv,and when i used my key to open the door the alarm went off,and disconnect the viper box,and bought a new remote,and when im trying to program my new remote and plug my...
You have to turn your ignition on and press the valet button switch, to turn off the alarm. Then, you have to use that same valet button to learn the remote to your alarm, following the steps in the installation manual.
1helpful
Viper 791 XV Automatic Start Not Working
Try putting the key in the key cylinder but do not turn it at all. Then try and remote start the car. If it works then your bypass module is bad and needs to get replaced.
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
