My Mustang Cobra has a Viper alarm system on it and I can't get the alarm to set.The light thats mounted on the dash stays on but does not flash. It worked when I had it installed, but I think I hit something on the remote that caused this problem. The switch that shuts the system off is up under the dash so I know I did'nt hit that switch. My remote has a numder on the back of it CE0890 I'am guessing thats the model number.
Thanks
Patty
Under the dash, Your installer that worked on your Cobra should have put an valet button under the dash, It is a small round Black button, Ok with the driver door open,,put your key in the ignition and go to the on position, Locate the black button before you do this, once the ignition is on hold the black button down for 3 seconds hit it once more and then turn the ignition off, the light should start flashing again and the chirp for arm and disarm with work again, What you have going on is called Valet mode which is designed to put the alarm side of the system to sleep which can happen from accidentally bumping it.
Hope this was helpful.
That Crazy Install Guy.
Hi Patty try this leave the drivers door open and then push the arm then the disarm then the arm button agiain ,do this not to slow if it doesnt work ignition on then off and try again.
