20 Most Recent Remote Start System Questions & Answers
Does the remote diarm the alarm? Do you hear the " chirp chirp" when you press the unlock button on the remote? If not, then the remote is defective or needs to be reprogrammed to the alarm. If you do hear the " chirp chirp" but, the doors do not unlock, then the issue is with either the wiring from the alarm or the vehicles power locks. Did it work before? Do you have power door locks?
Remote Start... | Answered on Aug 10, 2018
I think you need to buy a new starter buddy if it won't engage you're going to need a new starter there's really no way around that but once you get a new starter you should be fine they're not too expensive
Remote Start... | Answered on Mar 20, 2018
have you tried changing the battery? also does the central locking work by the key or inside the car button?
Remote Start... | Answered on Jan 16, 2018
If it backfired it's quite often timing. I don't know what motor you have but see if you can check the timing. If it's not the timing check if the car has a camshaft and or crankshaft sensor. If one of those go bad she wont start. Another quick test is to spray starting fluid or some carb cleaner into the intake and swing it over ... if it starts you have a fuel issue. Maybe the pump.
Remote Start... | Answered on Oct 22, 2017
Glow Plug lol thats a remote l (more Info )
Remote Start... | Answered on Aug 14, 2017
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Remote Start... | Answered on Apr 09, 2017
The asterisk button controls the remote starter feature. Press and release one time, wait. The parking lights should flash confirming that the unit received the command. If pressing the button one time doesn't work, try two times.
Remote Start... | Answered on Feb 02, 2017
Just had the same issue with my remote start. 2006 f-350 with a 6.0 powerstroke. Remote start module was in virtual tach mode and that does not work with diesel engines. Just had to have the remote start reprogrammed and put back into tach sense mode. Hope this helps.
Remote Start... | Answered on Dec 18, 2016
Did you connect the tach wire of the unit to your car? if not you need to refer to your documentation to turn on or off the tachless operation for the unit to work correctly.
Remote Start... | Answered on Oct 15, 2016
problem is the low battery
have it load tested and charged up or replaced
remote or key still use the same bad battery
Remote Start... | Answered on Sep 03, 2016
Lock the driver side door then open it with key that might reset you anti thief to your remote.
Remote Start... | Answered on Apr 20, 2016
Consider how the switch will be used before choosing a mounting location. Check for rear clearance before drilling a 9/32-inch hole and mounting the switch.The GRAY wire in the two-pin plug may also be used as a (+) ghost switch input and can be connected to any (+) switch in the vehicle. (See Feature Descriptions section of this guide.)
This is from the installation manual for the Viper 300. To answer your question, it is probably camoflaged. They only needed to tie +12vdc to the input line. What does this mean? Well, my best guess is, they are using one of your switches on your dash to act as the Valet function. Look for where the Gray wire, from the wiring harness of the Viper goes to: that WILL BE your hidden Valet switch. Best of luck!
Viper 300 ESP Installation Manual Plug in Harnesses Super Bright Led Valet...
Remote Start... | Answered on Mar 16, 2016
It says its a Viper alarm system. . If the alarm system is active, reprogramming the ignition keys was a waste of money. The problem is in the control box for the viper alarm system. It has disabled the ignition because it thinks that is being broken into. there are sensors that monitor the the vehicles vibration and is probably a problem with one of the sensors or maybe even the control box itself.
Remote Start... | Answered on Dec 26, 2015
You need to re-program the TACH wire.. open the door start the car with the key, between 5 seconds press the valet switch 1 time and press it again and hold it until the led flashes and the car will beep and then turn it off and start the car with the remote and it should be programed now. if that doesn't work take it to a authorized viper dealer to have it fixed.
Remote Start... | Answered on Jun 10, 2015
Remote Start System  Logo
352 questions posted
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
jason
Colin Stickland
Colin Stickland
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Viper Vehicle Parts & Accessories
Most Popular Question
install alarm speaker viper
  • Vehicle Parts & Accessories
