Sony Playstation 3 (PS3) Console Logo
Posted on Nov 13, 2010
My ps3 console will not turn on; i get a light indicator flashes green, then blue then yellow then red and won't boot.
Anonymous
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Nov 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
27
Questions
Helped
2330
Points
79
Have your unit get fix thru SONY SERVICE CENTER
My ps3 turned off during game play and the light flashed blue green yellow and then kept flashing red and if I wait a long time and try again the fan turns on light god blue for one sec then turn a yellow...
I'm afraid you have gotten the Yellow Light of Death ( YLOD ) you will need to have your PS3 repaired by a technician or you can Google YLOD and you will find a repair guide.
When firing up the console it attepts to turn on then the lights flash green to yellow then flashes red ?
The yellow light of death...
The yellow light is used by the PS3 to indicate a hardware failure with the consoles motherboard. I'm sorry but you'll need to send it in to Sony.
PS3 wont turn on
PS3 red indicator light flashes with yellow means hardware errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only such yellow light flashing problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
2answers
From standby PS3 wont turn on.
that sounds like your main power supply unit
1helpful
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
