D-Link AirPlus DI-524 Wireless Router Logo
Posted on Nov 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the manual to install the Router - D-Link AirPlus DI-524 Wireless Router
Anonymous
Level 3:
Guru:
  • Master 610 Answers
  • Posted on Nov 10, 2010
Anonymous
Master
Level 3:
Guru:
Answers
610
Questions
0
Helped
175493
Points
1784
2answers
Download installation cd linksys wrt54gs
You could install the Linksys WRT54GS without any CD.
You could use the Linksys EasyLink Advisor to scan your network for the Linksys WRT54GS.
The Default IP-address is 192.168.1.1 so you should be able to connect to the Linksys with your Webbrowser when you do a factory reset of the Linksys.
Where to download the installation disk
Are you trying to setup router?
You can install your router manually.
You don't even need to run the CD>
Just open the setup page of the router and change the Internet connection settings manually.
See Linksys router setup
I dont have the disc for instal the router
You can install your router without Disc also. You just need to open the setup page and change the settings manually. Linksys router setup is very easy.
1helpful
2answers
I lost my belkin installation cd
You do not need the installation CD to use the router. Check this link to download the user manual and quick install manual. As well you can download an updated firmware for your router along with installation instructions.
Good Luck.
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
I need a driver for my router dg834n
1. check the manual for installation of the router there should be a installation wizard to connect you properly.
this is found on the installation disk that came with the router.
2helpful
4answers
I need to download a users manual for Linksys WRT160n wireless Router, Any suggestions
The Manuals are located on the Linksys website:
http://homesupport.cisco.com/en-us/wireless/lbc/WRT160N
Select Downloads, choose your version, and on the right you can download the manual.
1helpful
How to install if i don't have the installation cd of the router?
Here is a link to the setup manual. If you follow that step by step it is a piece of cake. If you still need help do not hesitate to ask and I will then walk you through it.
http://static.tigerdirect.com/pdf/netgear-WNR834B-manual.pdf
enjoy,
Lee
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
