Our washer acts as though it is going to turn on, but then does not fill up with water. On the last load that was ran, (which was towels) they were sopping wet when we took them out of the washer. When you turn the washer on, it does not pump water into the drum. The timer sets to 48 minutes and begins to count down, but nothing else happens, not spinning, agitation, or anything. There is no error code reported.
We have taken out the coin trap assembly to see if there was a blockage and there is none....
Does any one have any ideas? Please help!!!
It can be a few things.
Simple one first. Where your hose connects to the machine is a filter in eache hose. Clean those as they will plug up and cause this same situation.
2nd: If that does not help it can be 2 things.
Pressure switch ( stuck in full position)
or water valves in the dispenser area.
Follow LINK to get idea on parts and drawing of the machines. Just click on the sub components
Hello
I have the same issue...I have taken the water hoses off and cleaned the screens out, which they were filled with rust particales...
it is exactly the same as the above mentioned. any help would gratefully appreciated.
