Printer isn't recognizing the computer. It worked fine two days ago. Can you help me with assistance?
The issue which u r facing is" Communication issue"
Make sure u have installed the lexmark printer software...or else download it from the lexmark website(lexmark.com)..choose the s\w for ur operation system( Xp or vista(32bit or 64bit))...
If s\w is installed...
Check the USB cable..try different port...
Clear all the docs in the printer folder...
Remove the power adaptor and replung..restart computer..
When u unplug and replung the usb cable doesn ur computer give a pop up "found New hardware" ?...If it doesnt..then (Check if USB printing support,USB composite device are present in the Device manager...i.e Right click on "my computer" ikon-go to PROPERTIES-Hardware-Device manager-Click the plus sing near and check in the list )
U can also try...
Uninstalling the s\w....disconnect the USB cable..reinstal the s\w and connect the cable when it prompts to...
A
quick fix for most communication errors can be achieved by resetting the
printer and/or rebooting the PC. Simply disconnect the printer from your
computer. Reboot your pc. Unplug and re-plug the printer into the power source
to reset it. When the printer turns on, reconnect it to your computer. Then try
to print again once the computer fully recognizes the USB connection.
If
that doesn't help, try the steps below:
1.
Disconnect the printer from your computer.
2.
Re-brick your printer. Pull out the power supply,
black box where the power cord is plugged in at the back of the printer, and
put it back after 30 seconds.
2.
On your computer, go to Control Panel > Printers and Faxes.
3.
Delete the Lexmark print object.
4.
Reboot your pc.
5.
When your pc turns on, reconnect the printer.
6.
Wait until your pc fully recognizes the USB connection. To check, go to Control
Panel > Printers and Faxes. If you see a new Lexmark print object in the
list, then try to print a document again to verify that the problem is fixed.
You
may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/gKXn7F.
Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
my computer is saying that it is not communcating with the printer
