Chances are that is the bulb. Its a dual filament bulb. The brake portion of it is burnt out. try swapping it with the left side and see if it works then. If it works, get a new bulb.
There are possibilities
1) the button for the window is bad
2) the motor to take the window up and down burnt
3) the wire went out of its track
take door panel apart and visually investigate.
Thanks
Somewhere in the back there should be a removable plate which covers the computer that makes this unit work. I have a feeling that you will find something burnt on the "solder side" of the board.
What about the Microphone you are using---Is it the right one for this model? If its not a Mic problem then its a burnt transistor in your board. Keep trying something with the Mic. May have to get it serviced at a repair shop. Sorry,can't help much.
This is a sign of a short and should be looked at immediately. A smell like that is a sign of something burning. I could be the start relay and start capacitor with overload. But I would not sleep with the possibility of a fire. I will look over your model and see if I can find what this could be, Sea Breeze
If something is burnt,something made it burn !! These things dont smoke for no reason. Have the amp checked out, and also have the speakers and all the wiring checked for a partial short. Good Luck
