FixYa.com
Power Acoustik PS2-1600 Car Audio Amplifier
All Products > Power Acoustik > Car Amplifiers
Problems with Power Acoustik PS2-1600 Car Audio Amplifier?
Search inside Power Acoustik PS2-1600 Car Audio... Knowledgebase
Troubleshooting and Support
Solved Problems for Power Acoustik PS2-1600 Car Audio Amplifier RSS Feed Post a New Problem
power acoustik ps2-1600 blowing fuses
hello, i just purchased a power acoustik ps2 1600 power amp from a friedn really cheap  because he said it stayed...
1 Solution
Amp getting really hot
i have a power acoustik PS2-2200 amp and its hooked up to a Almani S5-12" and after about 3 min my amp gets really...
1 Solution
burnt smell
the amp was working fine and all the sudden i smelled wires burning i looked to see if maybe something had a naked spot...
1 Solution
legacy 1200 watts
i have a legacy amp installed and it keeps going into safe mode while im driving along....but when the car is parked the...
1 Solution
Amp
I have installed a amp into a figerglass boat, the radio is new and is working. However after connecting the amp I have...
1 Solution
Audio system makes extra noises... pops
Audiobahn Sub: AW1206T & Amp: A8002T subwoofer extra noise/pop i have also posted this under the subwoofer page...
2 Solutions
Subs going off the hook
my subs worked fine... then they just started to thumop without any music going to the amp. any ideas??
2 Solutions
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Amplifier TypeDual Channel
Bass BoostWith Bass Boost
BridgableBridgable
Power Output
RMS Power at 4 Ohms310 W x 2
RMS Power at 2 Ohms370 W x 2
Performance
Bass Boost Frequency40 Hz
THD at Rated RMS Power.02 %
Signal to Noise Ratio97 dB
Frequency Response10 Hz - 30000 Hz
High - Pass Frequency150 Hz - 1500 Hz
Low - Pass Frequency40 Hz - 120 Hz
Dimensions
Depth2.25 in.
Height11.25 in.
Width22 in.
Other Features
MOSFET ampYes
3 Way ReadyYes
Power Acoustik Contact Information
Main support number323-722-3333
Support FAX323-722-1122
Email supportTech-support@poweracoustik.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
