SOURCE: 50" Samsung Plasma with black screen
I had the same problem and had the TV serviced and found that the y board was blown $350 total. The repair guy explained that the board has a hot transister underneath that slowly leaked onto the board, but says that they can not get Samsung to admit to the problem. Works fine now but only have a 90 day warrenty on the parts.
SOURCE: Samsung 50 inch Plasma cracked
Sounds like a stressed area gave way.
Plasmas are high vacuum tubes with a lot of unsupported surface so your problem may not be uncommon.
Can’t promise you satisfaction in your unenviable situationbut you are not alone in your consternation with Samsung:
Samsung victims
SOURCE: Samsung Plasma 52 inch flatscreen vintage 2004 - black line
Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the TV menu you most likely need a new screen.
You can try changing buffers, reseating cables.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: screen went blank but still have audio
loud pop then no picture. still has sound 50 in samsung plasma mod s50hw-yb02
