Question about Samsung PS50Q91HD 50 in. HD-Ready Plasma TV
Tv went to black screen with audio working then
Samsung ps50q91hd tv went to black screen with audio working then after turning off and on again. now it has black screen and no audio. capacitors on power board look fine. no bulging or leaking.
Posted by sjelby1 on
Anonymous
    New Friend:
No power to tv light blinks on and off
Posted on Feb 27, 2010
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Why is my screen black, but my audio is fine on my samsung plasma tv? Could it be the capacitors?
Sustain fault. Contact the authorized service center. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 18, 2014 | Samsung Televison & Video
Won t turn on
You can try this:
http://forums.whirlpool.net.au/archive/1675197
Or you can send the power supply board to us to have a look and tell you why does it keep blowing capacitors.
Jul 16, 2014 | Vizio P50HDTV10A 50 in. Plasma HDTV
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV display is black; audio works fine. If I turn TV off and then back on the picture does display for a few seconds but then...
The backlight inverter which is also part of the power supply needs to be replaced. If you feel comfortable you can replace the blown capacitors on it.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Feb 10, 2018 | Televison & Video
Black screen after five minutes of watching. Audio is fine but no video.
What would need to be done here is some voltage tests on power board when set is working and then again when it is not, also a valuable source for some parts:
http://www.partstore.com/Part/Samsung/Samsung/LNS4051DXXAA/Samsung/Samsung/BN4400134A/New.aspx
Apr 30, 2012 | Televison & Video
My tv went black then started making grinding sound then weird red screen then went black again i unpluged
i have a samsung 32" that went black and made weird noises... it had a blown capacitor, shown here in the upper right corner, i just bought a entire board for 40$ from shopjimmy.com rather than dealing with samsung service, which i hear is way more expensive. its very easy to switch the boards. zelmer05.jpg
Apr 30, 2011 | Samsung Televison & Video
I have a ps50Q91HD plasma and have sound on inputs but no picture at all just a black screen, does not even come on at start up of TV.
Check if fuse F5700 is blown. Replace if necessary and then replace C5709 if fuse is blown.
Let me know if it works. If not, we can check other things.
Apr 07, 2011 | Samsung Televison & Video
Hello, would like to ask about my hanspree tv, 2 weeks ago the power just stopped so i opened it up (left it 24hrs with no power and had ground strap etc) and 2 capacitors had blown. I changed them and the...
The backlight controller is most likely faulty. It could be bad capacitors again, or the inverter board itself may need to be repaired - possibly faulty inverter(s). Try shining a torch close to the screen and see if you can see anything on the screen.
Mar 04, 2011 | Hannspree HANNSwing 32 in. LCD Television
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung PS50Q91HD 50 in. HD-Ready Plasma TV Logo
1,169 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
