Motorola Mobility H700 Headset Logo
Posted on Oct 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PAIRING MODE - Motorola Mobility H700 Headset
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Oct 01, 2010
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3073249
Points
27242
You can get the instructions on pairing on the link below.
http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Good Luck and please rate 4 thumbs up for the free answer
1helpful
How do i put lg hbs-700 into pairing mode
I had the same issue, fixed by using the Manual mode for pairing. From the manual:
2) Manual Pairing (Pairing with another phone or re-pairing)
a) With the Power off, press the CALL button and move the power switch to the
'ON' position at the same time for 4 seconds.
b) When the headset enters Pairing Mode, the LED indicator will show a solid
blue light. After the procedure repeat Easy Pairing steps c through f.
Steps C through F are to go to the bluetooth settings area and manually select the HBS-700 for pairing.
Mar 14, 2015 • Home
Phone cannot find headset
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone.
10helpful
How do i connect my bluetooth BH08 to my blackberry phone
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
How to install a bluetooth
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
2helpful
How to connect bluetooth BH-606 with computer
21helpful
How do i pair my motorola H390 bluetooth on a katana
Setting up bluetooth on va76r
1helpful
New phone need to connect with bluetooth
1helpful
My LG Voyager cannot find my Motorola Bluetooth H710
Connect ge bluetooth to blackberry pearl
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
