20 Most Recent Motorola Mobility H300 Wireless Headset Questions & Answers
The manual can be found here: http://www.motorola.com/mdirect/manuals/qg-H300_9495A08A.pdf
Mark
Motorola Support
Motorola... | Answered on Aug 22, 2014
Try the passcode "0000." That's "zero zero zero zero."
Motorola... | Answered on Nov 16, 2012
Yo i have the same problem except with a Samsung WEP250. I Disabled and deleted it off of my phone. And Now it wont scan my ps3. It might be the bluetooth problem. Go back to the store and ask them what went wrong. I am going to do the same.
Motorola... | Answered on Apr 21, 2012
If your trying to "pair" it with another device, the code should be 0000..four Zeros
Motorola... | Answered on Apr 23, 2011
How to Pair (Connect) a Bluetooth Headset to Your Phone
So you've heard of this new thing called "bluetooth..." But what is it? ...And what does it do for me? It's wireless technology that can link your phone to a headset, computer, another phone, or in extreme cases, your car and home.
We'll just start with the basics and connect a headset to the phone
Instructions
Things You'll Need:
* A Bluetooth cellular phone
* A Bluetooth Headset
Blue tooth can simply be called "a generic wireless technology that can connect your phone, computer, headset, PDA, laptop, and any other enabled device to each other."
In essences, it was designed to be a universal wireless connector between devices.
Ok... Here we go.
Make sure that both your phone and new headset are charged up.
Since every brand of headset is different, please refer to the instructions for "Pairing", but I will tell you how the most common headsets pair.
By the way, "Pairing" just means "connecting". If you find it more simple, you can substitute the word.
On most headsets, from the Headset being off, hold down the answer/end button down until the indicator light(s) glow a solid color (usually blue). This may take up to 10 seconds. They might flash first, then after a couple more seconds, go solid on.
On your handset, find the bluetooth menu.
On most phones, go to the settings menu, then to "connections" and then "Bluetooth". You are looking for a link to "Add a new device".
On Motorola phones, it is in the "Handsfree" link. Select [look for new device] select this option, and hit "OK".
Nokia Phones: look for "search for new audio enhancements". Hit OK.
On Samsung phones: **Bluetooth menu might be under "tools"** Look for "Add new device". Hit OK.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
At this point, the phone MAY ask if you want to use the headset. This means all audio from phone calls would be routed to the headset rather than in to the phone's speaker or earpiece. Select yes, or ok.
Your headset is now set up for you to talk on like a REALLY important CIA agent or something of the like...
Keep in mind that when a call comes in, the phone will still ring like normal.
You can answer the call by either:
1. Pulling the phone out of your pocket and hitting the answer button.
2. Touching the answer/end button on your headset without reaching for you phone.
The range of your headset is up to 30 feet, in a direct line of sight.
If you go into another room, your range may be decreased.
If you do happen to go out of range, the call will be transferred back to the phone, and as soon as you are in range again, touch the answer button on the headset to let the phone know you're back in range. It will re-transfer the call back to the headset.
If you turn off the phone, or headset, you can repair them again simply by going to the bluetooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
*** Please note that you do not have to hold down the answer/end button on the headset until it goes a solid on again.
Tips & Warnings
If you have difficulty, please feel free to contact me and I'll help you get things sorted out.
Motorola... | Answered on Apr 03, 2011
Try 0000
Motorola... | Answered on Mar 01, 2011
startingwith the power off push and hold the call button while the head set turns on....then continue holding the call button until the light turns blue that has enabled the pairing mode now the pin code for all h300 model bluetooth device is 0000..i hope this helps
Motorola... | Answered on Feb 22, 2011
Most motorola devices use 0000, although Motorola advise some models use 1234
Motorola... | Answered on Feb 10, 2011
I have been told all Motorola Headsets use 0000.
This is confirmed by a nice set of basic instructions here
BEFORE YOU BEGIN INSERT BATTERY START BLUETOOTH Feature ...
Motorola... | Answered on Feb 02, 2011
User Manual for the Motorola H350 Bluetooth headset!
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/H350_QSG.pdf
Motorola... | Answered on Dec 26, 2010
Try 0000 or 1234
Thank You
Motorola... | Answered on Dec 03, 2010
With the device off press the telephone button on the device until a solid blue light is shown. Then on your phone search for the device and enter 0000 to pair it. Here's the weird thing (for me) - the device HAD to be on my ear for it to work. Testing it when it was on my desk or whatever just didn't work at all.
Motorola... | Answered on Nov 18, 2010
The passcode is the same that you have entered in your phone . so switch on to activate the bluetooth in both the devices, the phone and the headset, the accept to connect by the passcode.
Motorola... | Answered on Sep 01, 2010
Due to some reason this may happen:
Battery might be weak or in a state of dead stone or loose contact.
1)Open the battery door at the back of the
headset.
2)Insert a new battery so that the + and -
markings match the markings in the
battery compartment.
3)Close the battery door
If this is working fine before and now you have this problem the microphone soldering might be loosened out.You have to re-hot it.
If you have warranty,You could take it to the service center,If you have warranty you can ask him to replace the one.
post a comment for further assistance.
thank you for using fixya have a nice day:-)
Motorola... | Answered on Aug 26, 2010
You can download and print the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Motorola... | Answered on Aug 02, 2010
The default passcode for this headset is 0000.
Motorola... | Answered on Jun 10, 2010
Motorola Mobility H300 Wireless Headset Logo
112 questions posted
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Radio Communications
Most Popular Question
want upgrade
  • Radio Communications
