Sony PlayStation 2 (PS2) Console Logo
Posted on May 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Parental Control My PS2 won't lt me change the rating thing. I bought it used, so I don't know the password. I think there is a default password, but I don't know what it is.
Anonymous
Level 2:
Champion:
  • Expert 207 Answers
  • Posted on May 28, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
207
Questions
0
Helped
168130
Points
346
Go to the sony website and check out the ps2 forums... there is but you need your number on the back then you can decode the default!
1helpful
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
1helpful
How to reset password on playstation 2
Hi Jessica
There are two methods to reset the Parental Control on a PlayStation 2, the Quick Method and the Easy Method.
The Quick Method to Reset Parental Control
  • Power on the PS2
  • Press the Reset button
  • Inset an R-rated and wait until the board comes up telling you that Parental Control is on
  • Hit the Select button
  • At the enter password prompt, hit the Select button
  • At the Delete password prompt, enter in your password
  • Hit the X button
If you do not know the Parental Control password on your Ps2, try the known defaults of 1111 and 7444.
The Easy Method to Reset Parental Control
  • Unplug the PS2
  • Wait approximately 72 hours
Hope this helps :)
I have a sony playstation 2 i do not know the parental password and i cannot watch movies my daughter bought becuz it will ask for parental control to be set to level 8 and u can only say yes or it will...
try passwords 1111 and 7444. these are known sony default passwords. if that doesn't help, unplug it and leave it like that for 72 hours. that should drain the charge enough so it "forgets" the password.
6helpful
2answers
Need to change the parental control password
press select on your controller and then enter password 7444 this will delete current password and allow you to set a new one...
1helpful
2answers
Over ride the parental control level
Ok first try 0 1 2 3 because that is the preset code for the ps2 or if that dont work insert any dvd movie, go to setup and access the parental control settings(press select) When asked for your code enter "7444"; It will prompt you again to type in your password. Type "0000" and then scroll down to the movie rating options and choose "off". Hope it helps you out!
2answers
Parental Control
I think the default password is all 0's, but I'm sure they told you that if you called them. the only thing I could think of would be to try "easy" passwords such as all 1's all 0's etc.
Playstation 2
when you are asked to enter the password press 'select' and then insert '7444' and you will be asked to enter the new password just enter any 4 digit number. If you want to clear the password completely then, during the film press 'select', 'setup', 'parental control' (tab) and there turn it of.
3answers
PS2 parental control
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!
150helpful
14answers
PS2 PARENTAL CONTROL CODE
This is the only way to turn "off" parental control lock on the custom setup screen.
1) turn off ps2 with no dvd in drive.
2) turn on ps2 and insert dvd in drive.
3) when it asks about parental password, choose 'yes'.
4) when prompted for password, press 'select'.
5) the prompt will change and say 'delete password'. enter '7444'.
6) enter a new password (0000 works).
7) registration complete, dvd will start playing.
8) once the movie starts, press 'select'.
9) click the 'stop' icon.
10) click the 'stop' icon again (the icon must be gray even when you have it highlighted).
11) navigate to 'custom setup' ('select', setup icon, custom setup icon)
12) move to parental control option, press right directional button, enter password (0000).
13) move down to 'level'.
14) move up to desired level (off is at the top).
15) click 'x'.
16) go back to 'select' menu options, and press 'play'.
17) while movie is playing, eject disk and remove dvd.
18) turn ps2 off using switch on the back, keep off for five seconds.
19) turn on ps2, put dvd back in.
20) happy dance. ;)
Video Game Console
Start a DVD, then stop playback. Clear "resume play" (press stop twice), goto the Control Panel, the select SETUP, then ADVANCED SETUP. Select PARENTAL CONTROL, then press Select. Enter the number 7444.the old password is clear, now you can set a new one and change the rating.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
