Lexmark P3150 All-In-One InkJet Printer Logo
Posted on Sep 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to test printer with no conection to the PC only test page. What buttons Can I press for to print test page directly of printer?
gggg
Level 3:
  • Master 904 Answers
  • Posted on Sep 27, 2010
gggg
Master
Level 3:
Answers
904
Questions
Helped
520747
Points
1791
Hi, you can't print a test page directly from the printer, but since it's a copier also, you can copy a page of text or graphics to make sure everything prints okay. Just place a piece of paper on the glass and press either the black or color copy button. (The computer must be on to make a copy.)
Why does my printer only print half of a page?
Let's start by trying this:
Unplug the printer power cord from the printer and the wall.
Turn off the PC.
Disconnect the USB cable from both ends.
Plug the printer back in and turn it on.
Now, can you print a self-test page from the printer?
Make sure there is unused, plain white paper loaded in the input tray.
On the product control panel, press and hold the Power button and the Cancel (X) button at the same time.
Release both buttons. The diagnostic page prints.
If that does not work, are there any blinking lights on the printer? This document might explain them: Blinking lights.
If the self-test page does print normally, reconnect the USB cable, turn the PC back on and try to print a Windows test page:
Click the Windows icon and then click Control Panel . The Control Panel opens in a new window.
Click Hardware and Sounds .
Click Printers . The Printers folder opens.
Right-click the printer icon in the Printers folder.
Click Properties . The printer Properties window opens.
In the General tab, click Print Test Page . The Windows Printer Test Page prints.
If you have problems printing from Windows, you can try some of the troubleshooting steps in this document:
Printer Prints Blank Paper.
Finally, you may have to uninstall and reinstall the print driver.
How to clean head HP 7260
HP Photosmart 7150 and 7260 printers
  1. Make sure plain paper is loaded into the In Tray.
  2. To perform the first level cartridge cleaning is a spit and wipe, press and hold the Power button while pressing the Cancel button twice, then release the Power button. The printer will generate a series of noises as it performs the cleaning.
  3. Print a test page from the computer.
  4. Once the cleaning has completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 5.If the print quality is acceptable, disregard the subsequent steps.
  5. To perform a second level cartridge cleaning, press and hold the Power button while pressing the Cancel button twice. Release the Power button and press the Resume button. The printer will generate a series of noises as it performs the cleaning.
  6. Print a test page from the computer.
  7. Once the cartridge cleaning has completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 8.If the print quality is acceptable disregard the subsequent steps.
  8. To perform a super clean, press and hold the Power button while pressing the Cancel button twice. Press the Resume button twice then release the Power button. The printer will generate a series of noises.
  9. Print a test page from the computer.
  10. Once the super clean has the completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 11. If the print quality is acceptable disregard the subsequent step.
  11. To perform a pen nozzle test, press and hold the Power button while pressing the Cancel button eight times. Press the Resume button four times then release the Power button. The printer will generate a series of noises then print a page displaying a test pattern. If there are gaps in the printouts the cartridge(s) may need to be replaced.
Printer saying recieving data and is not printing
First check the printer itself is working OK by printing a test page.
Most printers have a power-on self test (eg press feed button while pressing power on - please consult your manual). If the test print is OK, then it's the PC or connecting cable. You could try any other PC or laptop (you would have to instal your printer software first) but just try re-installing your printer software first on YOUR computer. If that doesn't work try any other PC or Laptop available as directed above.
USE A FILE THAT YOU HAVE PRINTED OK BEFORE IF POSS.
If none of the works then the cable is suspect.
1helpful
Hello, my problem is that my laserjet printer p1005 doesnt print anything.. whenever i command it from my pc it doesnt do anything.. i tried changing cartridge but still same prob.... please helllppp...
First, print an Engine Test Page.
To print an Engine Test Page, open and close the cartridge door five times while the printer is in ready mode. The printer should print one page with multiple horizontal lines.
If the engine test page printed, is a comunication problem (PC configuration,PC/Printer conection/Driver bad installed)
3helpful
New ink colour printer not printing black. Prints all other colours but not black when print tested
Hi there!
If the test page from pc or the machine test page doesnt show black, what you can do is to clean the printhead. To do that press the Ink Management button on the control panel and select cleaning press ok then press the up or down arrow key to select Black press ok and press Black Start. After the cleaning process print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times.
Hope this helps Please rate if it worked Thanks!
How to print configuration page hp officejet g55
Printing a self-test page Method one: Print a self-test page from the All-in-One control panel
  1. Press the Menu button.
  2. Press 3 or use the arrow keys to scroll to Print Report , and then press the Enter button.
  3. Press 5 or use the arrow keys to scroll to Print Report , and then press the Enter button. The self-test page prints.
Method two: Print a self-test page from the computer
  1. Click Start and click Printers and Faxes .
  2. Right-click the appropriate product, and then click Properties .
  3. Click Print Test Page . The self-test page prints.
1helpful
Can't figure out how to print test page when not connected to PC
Please follow the steps given below to perform a Self test:
1. Turn off the power by pressing the Power button once.
2. Press and hold both the Start button and the Power button.
3. Once the screen displays Mfg Menu enabled, release both buttons.
4. Press the Mode button three times. All the indicator lights will go out and the screen will display LCD button test.
5. Press the up arrow (Up arrow button) twice. The screen will display Single Test Page.
6. Press the Start button once. The self test will begin. The printer will stop once the page has printed in full.
7. Turn the printer off and then back on to disable the manufacturer menu (Mfg Menu).
Picture crops strange
HP Photosmart 7550 printers
  1. Ensure that the memory card has been removed from the memory card slot.
  2. Make sure plain white paper is loaded into the In Tray.
  3. On the control panel, press the Menu button. Using the directional arrows, select Clean Cartridges .
  4. Press the OK button.
  5. After confirming that paper is loaded into the paper tray, press the OK button.
  6. Once the level one clean cartridge test page has printed, examine the printed page. If the print is not clear and/or there are lines in the color bars, continue to Step 7. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  7. Press OK to print the second level clean cartridge page.
  8. Once the second level clean cartridges test page has printed, examine the printed page. If the print is not clear and/or there are line in the color bars, continue to Step 9. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  9. Press OK to print the third level clean cartridge page.
Hp 3745 desk jet problem
check whether its printing the test page properly directly from the printer not from the pc.for that print
1)just ON the printer
2)press the ON button
3)do not leave the ON button and lift the cover of the printer completely up and down 4times.
4)if you want to change the cartridges which front cover you will lift ,that you have to lift 4times up and down by pressing the ON button ,then leave the ON button the printer test page will come out of the printer .
5)keep the paper in the tray.
6)check that printout if its proper the printer is perfect
7)if the print is improper then the printer is having some problem.
8)also try changing the cartridges and see if its same or better prints comes out.
thanks.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
