We had similar symptoms with our WTW5640. It turned out the belt has come off the motor and drum pulleys. The second time it did this, it damaged the pulley on the drive motor. I believe the root cause of this problem is that the nut which holds the drum pulley on needs to be installed with loctite, so that it won't loosen and begin to wobble. Problem is that the drive motor pulley cannot be replaced by itself... you need to replace the entire motor. The part itself is $250+. We decided to cut our loses and dump the whirlpool. We'll never buy another whirpool appliance again. Our washer was only 3 years old, while the one we owned before it (Kenmore) lasted 23 years.
SOURCE: washer machine drains while filling
If the pump is actually coming on at all times, then I imagine this machine has a completely electronic control system ? - i.e. No mechanical timer ? - If this is the case, then the switch that controls the pump is an electronic solid-state device, or, more rarely, a relay on the board. Looks like you'll need a new power board.
SOURCE: WTW6600SW2 Won't Drain
We had the same problem. In our case a penny got down under the tub and into the pump. It caused a crack in the pump and it could not get the suction it needed to drain. A new pump solved the problem. Parts and labor to the tune of $195.
SOURCE: washer won't drain after rinse cycle
If you lay the drain hose down into a bucket does water come out fairly quickly?
If so then it is not a blockage
You may have a coin or other small object in the pump which stops the impeller turning so no pumping action
Only solution is to check if the pump is free to turn either via the filter opening or taking the back panel off (Remove power before doing so ) and turning the pump by hand (there will be a fan blade on the end which is connected directly to the impeller.
If that will not turn very easily then you need to take off the hoses and check what is happening with the pump unit
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washers however, your whirlpool duet washer can be reset to resolve the control lock
problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to
reset the control. Please get back to me if you have any other questions.
Kevin
