Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Top load washer won't go through cycle
Water fills and shuts off when it reaches proper level, agitator does not operate for wash cycle. turn it to spin and it will spin and drain. turned it back to rinse, and it filled and then would not agitate again. turned back to spin and it spun and drained again
Posted by Jeff Davis on
Kenneth Southwell
    New Friend:
  • 31 Answers
Modle problem here its the main board common fault with this model good luck
Posted on Mar 26, 2010
Washer keeps fling with water and will not agitates it will drain and spin
There is usually a small hose from the outer tub to the water level switch. This ia actually a pressure hose to make the water shut off. If a hole is rubbed into it, you loose the pressure and the washer fill will never shut off. That pressure is needed to switch machine from fill to agitate once it reaches the proper fill level.
Apr 07, 2016 | GE Washing Machines
The machine fills up but won't spin or agitate
Fill valve sends a signal to the timer to turn to agitate cycle, could be a loose wire, or possibly a bad timer. Fill valve is obviously ok
since the water shuts off at the proper level.
Mar 07, 2015 | Washing Machines
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
The water comes out in the detergent/softerner liquid dispenser; instead in the main washer.
Water Problems
Sometimes water will not enter the machine in order to properly wash clothing. In that case, the water may be turned off or the water fill valve, water temperature switch or timer may not be functioning correctly. A defective water valve or timer can also cause the machine to not enter the spray rinse cycle. Another issue that arises is when the water will not drain out of the machine. The drain may simply be clogged, or the drain hose or pump may be malfunctioning. Water will splash on the floor if the pump or water valve is not working, or if the machine is operating on a low level of water with a high level of agitation, which means the force that promotes all the functions of the machine.
Cycle Problems
Malfunctions of the various cycles are common as well. If no agitation occurs, the agitator spine may be stripped, or the motor or internal transmission system could be broken. If the machine will neither agitate nor spin, the belt or coupling is most likely the problem. There are a number of issues associated with either no spin or a slow spin including an open lid, defective lid switch, spin tube, wigwag, timer or wigwag wire or a drive belt that is not properly adjusted. When the motor will not run at all, first check the power cord to make sure that it is plugged in. If that does not solve the problem, issues are found in the timer, lid switch, motor or water level switch.
Other Issues
Sometimes washing machines will excessively vibrate or "walk," meaning that they begin to inch forward while the motor is running. Check inside the machine to see if there is an unbalanced load. Heavier items, such as sneakers, cause vibration as well. The load can be fixed and any unnecessary items removed. If the problem persists, other possible issues include an improperly leveled machine, a worn-out snubber, broken suspension springs or shipping pins that have not been removed. Another problem that arises with washing machines is oil leakage caused by transmission failure, which is one of the more costly issues to fix.
Cycle Problems
Other Issues
Mar 12, 2011 | Washing Machines
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Sep 01, 2008 | Washing Machines
    Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
    238 people viewed this question
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
