Troubleshooting & Support
Hot Topics:
- lxr7244jq1
- spin
- manual
- washer
- sav205daww
- model...
- spin cycle
- water drains...
- not go spin...
- bottom front...
- sav205daww...
- wfw9200sq02
- heavy duty
- llr9245b
- drain pump
- ghw9150pwo
- lsq8543jq1
- spin cycle goes...
- imperial ...
- ghw9150pw4
- ghw9100lw2
- la5558xt
- ghw9100lq
- bottom front...
- switch
- WATER LEAKS
- model
- agitating
- ghw9150pw1
- ghw9400plo
- View All »
Problems & Solutions
Seems like the drum is
Hi from retired Englishman in SW France, It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and...
My washer is very slow
The hoses and inlet valve have screens that get plugged, check those areas.
Only spins slow, will not
The problem is likely in the clutch and brake assemblies. The clutch hub is attached to the spin pinion gear and as the spin pinion gear...
washer will not drain
there are mainly two reasons for this a bad lid switch but if the washer is washing then ignore that. next and most common is a bad water...
I have a whirlpool Heavy
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to...
Washes until end of wash cycle and stops working
replace lid switch where yout timer asymbley and controls are a screw in the bottom left and right corner remove and flip timer assymbley...
Whirlpool heavy duty super capacity plus washer
Your model may have a flexible (break able) drive component between the motor and the transmission. Check that, it is a pretty easy...
The washer is not draining
If it fills up and stops the lid switch may be the problem. Push down on lid or switch.
top half of agitator not working bottom part is
Hi, I'd suspect the agitator gears (dogs) are worn. You'll need to remove the top of the agitator, (the cap) and then the 9/16"...
agitator is not agitating. Cant seem to get
If this is a Whirlpool manufactured TOP LOADER, and this is a simple matter of the agitator not working, but everything else does, you may...
no cold water Whirpool Extra Large Capacity plus
Remove the hose and look inside the water inlet valve for a screen pull this out and clean if dirty. Also check the screens in the hose. If...
Whirlpool washer LXR7244JQ1 has leak
There is a video at www.appliancehelponline.com/servicemanual.html this will show you how to disassemble. No special tools required. When...
The agitator doesnt work anymore on my whirlpool...
The agitator cogs may be worn. Please take appart the agitator to check it. If they are worn it is best to replace the whole assembly. It...
My whirlpool 3.2 cu ft washer is making a loud
Use a screwdriver to remove the screws holding down the control panel,then swing it upwards. Use a flat blade screwdriver to pop these...
our belt came off but we don't know how to put...
1. Look and find the pulley tensioner of your washer, and loosen it up. This is a bolt holding the motor base,and allow the base to...
See all Whirlpool 3.2 cu. ft. Super Capacity Plus Washer Solutions
Unsolved Problems
whirlpool heavy duty super capacity plus washer...
Looking for a manual
manual for whirlpool super capacity plus washing
manual for whirlpool super capacity plus washing machine
whirlpool washing machine model la5558xs won't
whirlpool washing machine model la5558xs won't spin
my washer goes through all cycles but the wash.
my washer goes through all cycles but the wash. The machine continues to fill with water but never washes.
whirpool super capacity plus will not start Timer
whirpool super capacity plus will not start Timer is working so power is running but machine will not start.
My agitator has two parts.
My agitator has two parts. Lower and upper that operate either independently or together. The "clutch or...
counter balance weights seem to
counter balance weights seem to be loose
See all Whirlpool 3.2 cu. ft. Super Capacity Plus Washer Problems
Manuals & Guides
TopDo you have a manual for Whirlpool 3.2 cu. ft. Super Capacity Plus Washer? - Upload it to FixYa!
Upload a manual for Whirlpool 3.2 cu. ft. Super Capacity Plus Washer
Specifications
TopProduct MPN
Full Product Name:Whirlpool 3.2 cu. ft. Super Capacity Plus Washer
MPN:WTW5320S
What's your problem?
Fix-O-Meter
26,460
26,460 people have viewed this product
- 235 people asked about this product.
- 80 people found solutions for this product.
- 7 people have added this product.
Does your front...
Checking the...
Keep Washers...
