When turning on the playstation comes with the following error message the hard disk's file system is corrupted and will be restored with the option ok , once this has been done it goes back to the original error message
Re: When turning on the playstation comes with the...
Take your ps3 console to neay by repair shop,,,
if the same problem exists use repair guide to fix this problem.
click here to download repair guide.............
If you are getting the corrupted drive message this means that you have corrupted data on the hard drive or there is something wrong with the hard drive. If you have tried the built in repair options and they do not work then you will need to format the hard drive with an externally with a computer. The link below will help you do this.
the only thing that you can do is to replace your hardrive and then reset it this will clear any error messages that you may have had because of your hardrive being corrupted
faulty hard disk, the only option is to replace it with a new one. bad news, you lost all your data, when this happens, make backup of important data next time.
If the restore option for the PS3 is not working this means that you will need to pull the hard drive and format with a computer. The link below will help you do this.
Be sure to folleow these instructions to the letter, you could damage your PS3 if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
The current version of the ps3 firmware has a “recovery console”. You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options
1. Restart System: Restarts the PLAYSTATION®3 System. 2. Restore Default Settings: Reset all system settings back to default. CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files. 4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3. 5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch. 6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive isoption 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
Here is a video of the recovery screen. www.youtube.com/watch?v=m0SPmkV-jco If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
There is an alternate way to restore your HDD. Turn off your system and when u see the red light, hold the power button in front until you hear a total of 4 beeps (1 alone, 1 alone, 2 together). It usually works on second try. it should show a screen and say hook up controller with a usb cord. Then it should show i think 6 options. Choose the restore option. it should work.
Hope it works and wish you all the best! P.S.- I just got the 80010514 error on my ps3 and my ps3 games dont work anymore :(
