SOURCE: No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
SOURCE: akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
SOURCE: sonix lcd tv 27lc 27m6s
Here is what you do, Open the back cover. Check the heat sink by tweaking it around. Get a small fan which is usually the size of fan over the processor in the desktop PC. connect the positive and negative wire of the fan from the power supply lines within the tv use nearly 3.3v line. now place the fan in the top corner of the tv near the heat sink for the cooling purposes. fix the fan with tape or glue so that you can easily close the back cover.
SOURCE: need code
hi i have a baird or42bafhd tv and iv lost the book and need to no the specific features could you please help me
SOURCE: HDMI socket broken on 42 inch Baird TV
Depends if you can find a shop that can do surface mount repairs. Not all do it. Most usually replace the whole board. Then it would depend on the price of the board and labour.
