Question about LG 42LC2D 42 in. LCD HDTV
Need code 42 inch baird lcd, model is x42dtv, i have just had sky plus hd installed and have tried all the codes under baird but none of them work to control my tv with the sky remote does anyone no the code
Posted by matty2k2k1 on
  • yahoouser Apr 30, 2009
    CAN NOT GET SKY REMOYE WITH BAIRD TV OR42BAFHD. AM I THE ONLY ONE. IF ANY ONE KNOW'S THE CODE PLEASE ANSWER, AS I AM FEED UP USING 2 REMOTES.
Anonymous
Hi i have a baird or42bafhd tv and iv lost the book and need to no the specific features could you please help me
Posted on Mar 24, 2010
Anonymous
  • 325 Answers
Try this
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0117
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Posted on Sep 17, 2009
Does anyone know how to reset the child lock code for a Baird 42 Inch LCD TV Model: X42DTV
alot of companys put in an over ride code that is usually 4 of the same numbers in a row try this
0000
1111
2222
3333
and so on all the way to
9999
good luck
I need a code for a bush bpdp 42 hd 2 tv for my sky hd box
2577 worked for me for the Bpdp 42 hd bush tv
Hi i have a 42"
At the back of your lcd there are screw..open your unit and re-insert all cables specially going to display section ...probably theres a loose connection
Code problem
I got a tip for this and in this tip are codes you can TRY, now the sky universal remotes are senstive to tv codes so you need to try the manufacture codes if that does not work then you need to ditch the sky remote and get a remote that works with the sky box and the tv as a solution. IN my tip there are remote solutions as well, please do not shoot the messenger I am not sky or the manufacture I am just helping for free,
http://www.fixya.com/support/r4873816-universal_remotes_remote_codes
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
2helpful
I need to download a users manual for a Baird 42" tv lcd
Try the following sites for the users manual
tv.manualsonline.com/ex/product/headline/.../Baird/.../PR42BAIRD www.user-guides.co.uk/.../baird/baird42/baird-42-inch-tv-online-manual.html
1helpful
I need a 4 didit code for my remote for my neon telly
Neon are a brand made by Cello.
This is from their FAQ page here
http://www.celloelectronics.com/faqs#
"There are no codes available for the Sky remote controls, however due to a high demand from customer’s Cello have been working on a new remote control design which will be supplied with the latest range of TV’s as well as being available to purchase from Contrast Technology. This modern design will work with all 73 and 51 series LCD TV’s that use the RC08 and 09 remote handset and will operate the following satellite boxes:
  • Sky Digital
  • Sky Plus
  • Sky HD Plus"
3helpful
Sky remote code for tv model JO47 Baird
These are your codes,0117,137,221,371,218,220,236,100...Here is a link for directions, www.digitalsat.co.uk/skyremotecodes. hope this helps..
Need code compatible with sky plus remote
Funai- - I am a sky agent & have the codes for all makes and models of tv's - However you have already recived the code that would be used for your tv '0179' / it could be that you are programimg the remote wrong if this is not the case - I can tell you that because of skys changing thier manufactors of thier boxies & remotes that Not all remotes will acceppt the code or programing and unless you are willing to buy every remote new & old to find the one that will I'm afarid you're stuck with the remote for the tv-
however you can sometimes get comi-remotes that will work all your appl.-tv,dvd,video&sky+.
but check with the dealer to make sure before you buy or have it that if it dose'nt work you can bring it back.
I can do a search myself for a make but it will take a few days to get some feedback from my surplliers.P
14helpful
3answers
Technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
LG 42LC2D 42 in. LCD HDTV Logo
Ekse
