SOURCE: where can I get brother hl-2030 LASER PRINTER DRIVER
Hey,
The brother drivers and software require for the machine is available at
http://www.brother.com/E-ftp/info/index.html
Let me know if you need anything else.
Thanks,
Ekse
SOURCE: i want a driver of Brother HL 1030 Laser Printer
You can download the driveer for your printer on their website located at www.brother.com. Click on customer support and then downloads and enter the make and model of your printer. then just follow the prompts to download and install your drivers and/or software.
The Brother HL 1030 in USB mode is supported by Windows. When using a Mac with OSxx thru USB will show that there are no communications with the printer. One solution that appears to work with Leopard is to use the alternative communications software for USB connections called "usbtb" which can be downloaded at http://buymelunch.org/printing/usbtb (it's a free download).
If this does not work you will have to use a different parallel-usb adapter.
Good Luck,
LutherM
