Mitsubishi LT-3050 30 in. HDTV LCD Television Logo
Posted on Aug 20, 2010
The stand has been taken off need to put back on LT 3050
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
96
Points
LG RD- 14CA30M MODEL TV PICTURE NOT SHOWS WHEN HIT THE TOP OF TV PICTURE COMING,1 OR 2 MINUTS AFTER PICTURE GOESE THAT SHOWS RAINBOW COLORE AUDIO OK,,,SOLUTION PLZ
My canon 70d does not zoom and focus automatically
My guess is the self timer was accidently turned on
Description
Using the Self-timer on the EOS REBEL T3i.
Solution
The self-timer is useful when you want to photograph yourself or prevent camera shake caused when the shutter is released.
1. Set the power switch to <ON>.
2. Press < > button.
  • You can check the self-timer operation with the self-timer lamp, beeper, and countdown display (in seconds) on the LCD monitor.
  • Two seconds before the picture is taken, the self-timer lamp will stay on and the beeper will sound faster.
Attention:
With [ ], the interval between the multiple shots may be prolonged depending on the shooting functions settings such as the image-recording quality or flash.
NOTE:
  • After taking self-timer shots, you should check the image for proper focus and exposure.
  • If you will not look through the viewfinder when you press the shutter button, attach the eyepiece cover. If stray light enters the viewfinder when the picture is taken, it may throw off the exposure.
  • When using the self-timer to photograph only yourself, use focus lock on an object at about the same distance as where you will stand.
  • To cancel the self-timer after it starts, press the < > button.
2answers
Does the symbols stand for greater than or less than
This is 'greater than' >, eg X is greater than 3......... X > 3
This is 'less than' <, eg Y is less than 3......... Y < 3
So I have an EOS Rebel Xsi, and it has been working perfectly for the last couple of months. I turned it on and tried to take a picture in MF, but then a yellow light on the front starts flashing and...
Sounds like the self timer was accidently set.
Description
Solution
3. Press <Cross Keys> to select the desired self-timer, then press the <SET> button.
: 10-sec. self-timer (The remote control can also be used.)
: 2-sec. self-timer
: 10-sec. self-timer plus continuous shots. After selecting , press <Cross Keys> to set the number of multiple shots (2 to 10) to be taken with the self-timer.)
4. Look through the viewfinder, focus the subject, then press the shutter button completely.
Attention:
NOTE:
I formatted but its appear the same thing
Hello, Please do it and reply me whats the problem ,
Sony Ericsson Secret Menu:
> * > means press joystick or arrow keys to right
1. push joy stick to RIGHT once
2. press *
3. push joy stick to LEFT twice
4. press *
5. push joy stick to LEFT once
6. press *
The Service Menu will appears containing following information !
1. Service Info
a. Software Version
b. SIMlock
c. Configuration
2. Service Setting
a. Contrast
3. Service Test
a. Display
b. LED/Illumination - *This test is very cool
c. Keyboard
d. Buzzer
e. ********
f. Earphone
g. Microphone
h. Real Time Clock
i. Joystick Counter*
Lockstatus:
Shortcut to last dialed numbers: 0#
Shortcut to sim numbers: On main menu type a number and press #
If you change the language from default to any other language, then it may be difficult to switch to default language.
The shortcut is very simple. Just press
stands for right arrow button or joystick.
Secret Games: Snake on the T68
Go to Erix and then on the main screen press 123 and you will be taken to the game.
Reply me
Hello. I need a simple help (I think). If I have an webbadress like "http://my.adress.com/home.html" and I want to make a form that puts whatever you type in a textfield at the end of the...
A simple solution would be!
<form action="http://my.address.com/home.html<?php echo $name; ?>" method="get"><!-- Note a variable after the link -->
<input type="text" name="name" value=""/>
<input type="submit" name="submit" value="Submit"/>
</form>
<?php
    if(isset($_GET['submit'])) {
        $name = $_GET['name'];
I just purchased a JVC 47'' LCD just need to know how to remove the stand. I have it hanging on a Unti do not need the stand.
1. remove the 4 screws on the back of the TV (these are located in the deep holes above the stand)
2. after the screws are removed, the TV will lift from the stand.
The stands sits inside the TV. after the screws are removed the TV will still sit on the stand. you (and someone else) will need to lift it from the stand.
Need to change the back tire or put it back on the rim
Find someone with a racheting cargo strap. Jack up the mower (put a stand under it) and place the strap in the center of the tire and tighten it up...the tire side walls will push out againts the wheel and you should be able to get it to seal and hold air.
Mar 21, 2009 • Garden
Need to know which buttons are R and L
Need more information for this... if you would like help.. but it really wouldn't matter if you have your remote taken apart and you just need to put them back in but R stands for Right and L stands for Left if you didn't know that
Polaroid TV
You are correct. Polaroid does not make the screws available. You will have to obtain locally, per Polaroid.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
