the tv just turns itself off and red light blinks... then will just turn back on eventually or go...
(More)
the tv just turns itself off and red light blinks... then will just turn back on eventually or go back to a red off light
I have a 27" Polaroid LCD TV and all of a sudden when I turned it on the screen turned green...
(More)
I have a 27" Polaroid LCD TV and all of a sudden when I turned it on the screen turned green and I have no idea how to fix it. I messed around with the settings and nothing worked. Sometimes you can see a green picture but it usually scrolls from top to bottom. Help!!
After about 5 - 10 minutes my picture goes blank. Sound still works. This has been happening for a...
(More)
After about 5 - 10 minutes my picture goes blank. Sound still works. This has been happening for a couple of days. What could be causing this?
When i turn on my Polaroid FLM-373B T.V. it has no sound and the picture quality is bad, it has like...
(More)
When i turn on my Polaroid FLM-373B T.V. it has no sound and the picture quality is bad, it has like a purple color. What can I do to fix it?
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Anyone with AKAI problems can download their service manuals at http://esi.fox-international.com. Just select the product type and a list will...
written by Kongsberger
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
