Check the lid switch first,lift the lid a couple of inches and close it down,if it clicks the lid switch is good and you most likely broke the motor coupling.remove the twoscrews that hold down the top console,lift it up and with a screw driver pop the metal clips and disconnect the lid switch wires in the middle,it's a white platic connector,now remove the whole cover of the washer,down the bottom you'll see the pump.with a screw driver pop the two metal clips and remove the pump,next remove the tow screws and clips holding the motor in place and pull out the motor,on the back you'll find the coupling,there should be two pieces of white plastic with three arms on each piece and a black piece of rubber that goes in between the two white pieces,remove the old coupling and tap on the new pieces one on the motor shaft and the other on the tranny shaft,slide the rubber piece on the tranny part of coupling and then line up the other piece that's on the motor shaft slide it together and put everything back,it's easier than it sounds,let me know how you make out,if you sent the model number i could of gave you the part number,i think it's PL337
Thank you for your advice. The lid switch clicks so it must be the motor coupling. My model # is 110.24422300. I very much appreciate it!!
part number for coupling is 285753A and it's around 19 bucks,if you nedd help with anything else let me know,also if you can let me know how you make out with your washer,good luck
part number for coupling is 285753A and it's around 19 bucks,if you nedd help with anything else let me know,also if you can let me know how you make out with your washer,good luck.
