During the wash cycle the agitator free spins, which means the clothes only soak. If you push down aon the agitator, it begins to work properly, but free spins again when you release pressure.
Remove the top cap on the agitator and see if the bolt has come loose. If it is not there, the agitator will come loose from the gear case shaft and free spin.
The most likely cause for a washing machine that is able to still spin but still turns but the clothes are still very wet is a problem with the drain hose to the washer . Most of the time with this issue or whichever is causing it to not drain during the spin cycle means the water isn't draining off very quick enough and is essentially going back into the washers drum,that is re-soaking your clothing.
If this is a belt drive unit it could be the belt or whats called a actuator also call a shifter. This componet switches the gearbox from agitate during wash to Spin to extract the water from the garments.
Happy Holidays
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Turn timer to rinse cycle. let fill up and agitate. when it stops
agitating it should pause then start to pump water out. After about 2
minutes it should pause for 3-5 seconds then start again and spin. If
it starts the first time and never stops it will just continue to pump
but no spin. The 3-5 second pause allows the transmission to shift to
spin. If it does not do this the problem is your timer. You may need to
do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
The problem is 2 fold. The "knocking" noise is indicative of brake rub. The fix is to replace the rotor & stator. The reason that your clothing are coming out wet is because the brake is dragging along a polished stator when in spin and cannot get up to its proper speed as a result. The 2nd item that should be replaced is the thrust bearing assy. This is what enables the transmission to transition from agitation to spin... Hope this helps... Bill
Sounds like the agitator got dislogged during moving. In some machines the design allows for the agitator to move up and down alittle too much. Try this and this is only a guess. With the machine empty push down firmly on the agitator and move it back and forth as you do. You might hear a little "pop". If it does, try running the machine again. If it works problem solved, if not tell what happened.
