Printer won't get of of paper mode. Red light keeps blinking
Pirnter won't work. Place paper in for printing - it just pushes the paper all the way through without printing anything on it. Is is repairable or should I purchase a new one?
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
There is probably a paper jam since you shut it off as it was printing. Turn off the printer. Remove the tray and look inside. Remove any sheets of paper you see. Open the back of the printer (the pass-thru door) and remove any paper you see. Turn on the printer. If that fails, check the blink status against the manual's troubleshooting guide to locate a different solution.
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are: 1) Green On, Red Off = Printer Ready. 2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up. 3) Green Fast-Flashing, Red Off = Printer off-line. 4) Green Slow-Flashing, Red Off = Processing Data. 5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing. 6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset. 7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted. 8) Green Off, Red Off = Printer power is off. 9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode. 10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Is the paper pushed in all the way? Make sure the paper is firmly pushed into the paper tray, towards the printer.
Do you have too much paper loaded in the feeder? Reduce the paper to about 30 pages.
Hit the cancel button on your printer, or push the button next to the flashing light. If this does not work, power down your printer for 30 seconds. Now turn it on.
The printer reports a paper jam because the paper feed system cannot feed paper.
Look down into the place where the paper goes (the "automatic sheet feeder" or ASF) and you should see a fat wheel with a grey ribbed rubber facing. Place a single sheet of paper in the ASF and do a test print (right click the printer icon and select properties). Watch to see what happens in the ASF. The plastic panel behind the sheet of paper should move forward to push the sheet against the rotating rubber wheel, which should then feed the paper into the print position. This is presumably not happening! Can you what does happen?
If the expected movements are not happening, you need to remove the printer top cover to see what the problem is and resolve it - perhaps the ASF has come loose or something. This is easy if you know how to do it - otherwise it's likely to cause you to take a large hammer to the task! If you need help on this, please report back with a new post.
Hi Greenhorn,
Your info is slightly conflicting - I think.
As I remember the C60 has just 2 LED's:
1 - Green for Power
2 - Red for Error
The third button - Cartridge exchange - has no LED
Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong.
The error codes I remember are:
Printer status - Indicators - Priority
Power - Error
Power ON condition On -
Ink sequence Blink -
Ink Cartridge change mode Blink -
Data processing Blink -
Paper Out *1 - On
Paper jam condition *1 - On
Ink end (Black) *1 - On -> Blink
Ink level low (Black) - Blink-> Blink
Ink end (Color) *1 - On -> Blink2
Ink level low (Color) - Blink-> Blink2
Ink end (Black and Color) - On -> On
No Ink Cartridge (Black or Color) *1 - On
Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink
Fatal error *1 Off On
Special setting Blink2 Blink2
