Generally, a cable connection or cable issue. not all the color signals are making it to the projector. Try reseating the cable connections on both ends. If no changes, then try another vga cable
Hello, This could be a screen cable problem but it is normally a faulty screen even though it may look like a loose connection. Get a technician to check it for you.
Right click your mouse anywhere on your screen/desktop and select "Properties", when the properties window comes up selct "settings" tab and select the different resolution form the window on bottom left. Experiment with different resolution until you see the one you like.
After your laptop boots up into windows, hold down the Fn key and as your doing that press the F8 button that should switch the output from the vga connetor to the LCD screen on the laptop.
If you still don't get video then you'll have to reseat the LCD cable from the back of the LCD screen to where it connects to the motheboard.
If you still don't get video then its either going to be a bad LCD or a bad motherboard.
when digit the password to initiate does not initiate and it gives the following message me: The User Profile Service service failed the logon. User procases out cannot sees loaded
por favor la repuesta en español
Compaq Presario CQ60-215DX Note book PC
if it is just half of the screen and the rest is black- you need a new screen. If it is half the screen all squished together (you can see the whole desktop) you need to reload the video driver
