Hello :i have a bad projection tv Symptom :power won't turn on at all. make : rca model : P580690 Appreciated promptly response.
Sounds like my 32", its going to be one of three things,
Convergence board,
if it is this you will need to order one online and install it yourself, lots of guides online to help you with this process,
High voltage power supply,
again this can be purchased online and directions are available, if it is the high voltage supply, the tv will act like it wants to come one and maybe click a couple of times
Low voltage supply,
the tv will do nothing, now if the tv does nothing, the low voltage supply isn't the only possibility, but the most likely, check fuses on this one as they are easy
