My RCA D52W23 attempts to come on,emits a slight sound, then turns off. It does this several times before it times out.
The set is in shut down mode due to a fault detected in power supply/vertical or horizontal deflection circuits.
The common problems with this model that will cause the symptom you describe are bad power supply capacitors, bad flyback, bad HV cap in horizontal output circuit and cold solders especially under flyback area.
These are only the most common problems and it could be any number of other faults.
If you have electronic (TV) repair experience check the items mentioned, otherwise it's best to seek a qualified RCA tech for an estimate/service call.
Reply to this post if you need more advice.
