tv worked fine last night when we went to turn it on this morning the powe button is falshing red six timestv worked fine last night when we went to turn it on this morning the powe button is falshing red six times
You can't post conmments that contain an email address.
The blink code means that something on the board is over current/over voltage. It could be an overload of the +5 line (A/B boards) or the +5 line is shorted.
The TV needs to be opened up and the boards checked. You may be lucky and only need a thermal fuse. Also check your bulb.
The standby light blinks to indicate problems with the TV. Six blinks indicates an internal problem, I suspect with the lamp. I recommend contacting a Sony repair shop to vacuum out the TV and replace the lamp. Installing it yourself has no bulb warranty and you cannot vacuum it out without taking it apart. Lamps are $250+ each...
When a Sony TV flashes five times, that means that there is an AKB circuit fault. Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a
technician, as several IC and components must be tested and eventually
replaced.
in this set 3 blinks means lamp cover not set properly but i think that your problem is your 6x red blinks that means you have a problem in the audio section in your set(missing a voltage) or a themal fuse open.
