yellow and blue vertical lines on screen . Tried resetting, unplugging power, moving speakers. No...
(More)
yellow and blue vertical lines on screen . Tried resetting, unplugging power, moving speakers. No relationship with cable. It's same with video. They are very thin lines about 1 cm apart.
My Sony KDF-60XS955 has started shutting down green light starts flashing and TV comes back on in...
(More)
My Sony KDF-60XS955 has started shutting down green light starts flashing and TV comes back on in about 20 seconds. It has been doing this once a day for a couple weeks. No red light flashing only green.
When you turn the TV on it works for about 3 minuts then the screen goes dark and then a few minutes...
(More)
When you turn the TV on it works for about 3 minuts then the screen goes dark and then a few minutes later it comes back on. This process repeats. Is it time to replace the bulb?
my Sony Grand Wega, KDF_E42A10 is turning off on it's own. We have reset the the power several...
(More)
my Sony Grand Wega, KDF_E42A10 is turning off on it's own. We have reset the the power several times. It stays on for a few minutes and turns off again. Does the lamp need replacing. The TV is 4 years old.
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound Fan error 4 times - Fan1-4 Power is not supplied.(G2 board) - Fan...
written by SUPERMAN_B_1
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
