Sony KDF-50E2000 50 in. HDTV Television
Problems with Sony KDF-50E2000 50 in. HDTV Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Sony KDF-50E2000 50 in. HDTV Television RSS Feed
View More Results for Sony KDF-50E2000 50 in. HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Sony KDF-50E2000 50 in. HDTV Television RSS Feed
Answer
My sony 50 sxrd is shutting off every ten minutes or so ? I have replaced the lamp 2 months ago?
Answer
when i connect my computer to the tv it comes up with a green tinge, a bit of ghosting how can i... (More)
Answer
how do i resolve shadowing when i connect other devices to my tv. its a sony bravia kdf-50e2000
Answer
I have a Sony IDF 50E2000 that will come on for about 1 min. and then the picture/sound shut off... (More)
Answer
Red hues on our Sony KDF 50E2000 are lacking (blues, greens, yellows only) while watching tv with a... (More)
Answer
The TV is just over 3 years old. I replaced the Lamp 5 months ago. I check the lamp and it has NOT... (More)
Answer
replaced the bulb only a year ago..should not be the problem
Find a Manual
Sony KDF-50E2000 50 in. HDTV Television Manuals & Guides
Tips & Tricks
(Post a New Tip)
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
The Fl231 PROBLEM(CONVERGENCE NOT IN CUSTOMER MENU) ITC22 chasis
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and... written by willtab
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Sony KDF-50E2000 50 in. HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the Sony KDF-50E2000 50 in. HDTV Television
Owners Recommend
out of 3
Reliability
Ease of use
Value for Money
Rate and Review the Sony KDF-50E2000 50 in. HDTV Television
Write a review:
Rate this product:
Would you recommend the KDF-50E2000 50 in. HDTV Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Sony KDF-50E2000 50 in. HDTV Television
Key Features
Screen Size
50 inch
Digital TV Standard
HDTV · HDTV - HDTV receiver is integrated.
Projector Technology
LCD
Display Resolution
1280 x 720 pixels
Technical Features
Picture in Picture
Without PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Energy Star Compliant
Dimensions
Depth
16.06 in.
Height
32.56 in.
Width
46.61 in.
Weight
64.7 lb.
Connectors
Rear Input Connectors
S-Video x 1 · Component x 2 · Audio (RCA) x 5 · Composite x 2 · RF x 2 · HDMI x 2
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · Component x 1
Rear Output Connectors
Audio (RCA) x 1 · Optical Digital
Display Capabilities
Aspect Ratio
16:9 · 4:3 Enhanced
Built-in Tuner
NTSC · ATSC
Digital TV Standard
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Broadcast Format Displayed
Remote Control
Remote Control
Multibrand
Illuminated Remote
Non-Illuminated
Audio Features
Audio Output
Variable / Fixed
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Surround Sound Type
Virtual Dolby
Screen Text
OSD Languages
English · French · Spanish
Channel Labels
With Channel Labels
Closed Caption on Mute
Without Closed Caption On Mute
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 12 Watt
Sony Contact Information
Main support number800-488-7669
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
