Teflon sheet got damaged replace it if you are service guy or else better to submit in service center..users are not advisable to do this activity..Tech guys: Remove left,right,back & top covers, take out fuser assm, open it, replace teflon sleeve..
Two ways to reset your EPSON printer ink counter, ink cartridge, protection counter and more.
A. SSC Service Utility For EPSON Stylus Printers
This utility allows you to do many amazing things with your EPSON printers:
Work directly with CSIC in EPSON Stylus printers cartridges.
Reset or rewrite any chip using special add on device.
Freeze internal ink counters.
Reset internal ink counters even with empty cartridges.
Separate cleaning of color and black heads for all EPSON ink jet printers, powerful cleaning mode.
Hot swapping of cartridges supported.
Resetting of protection counter (even then it is already full).
More then 100 different EPSON printers supported.
This program helps people with high printing demands to save money (program works with both black and color cartridges). The software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers. Click here for the SSC Service Utility for EPSON Stylus Printers
B. Using the EPSON Ink Pad Reset Utility
"Parts Inside Your Printer Has Reached The End Of Its Service Life"
Generally, this error message is caused by the malfunction of non user-replaceable parts within your printer. If your product is displaying the "End Of Life Service" message, please view and complete the required information from the link below to proceed.
If you are trying to print on 'teflon' sheets - then use tray 1. And make sure that you set the driver to TEFLON, the driver in the application, that is.
