Expert
- Posted on Apr 29, 2010
Re: Whirlpool LSR8233E..2 problems..you have to slam the...
WHERE THE HINGE SCREWS ATTACH TO THE LID CHECK IF THEY ARE LOOSE. THERE IS A 10% CHANCE OF THIS. SONDS LIKE YOU MAY NEED A LID SWITCH AND AGITATOR DOGS. NOT TO EXPENSIVE DEPENDING ON WHERE YOU LIVE. I CAN HELP YOU YOU WANT TO PROCEED ON YOUR OWN.
first question is this a top loader if it is as to the agitator not spinning as much the part costs maybe 5-9 dollars and the part is called agitator dogs.as to your first question you might want to replace the lid switch should cost maybe 29.00 the most if your able to do this job yourself you would save alot labor alone on this job is where most technicians make there money you can look up marcone and they will not only be able to order you the part but they will also be able to send it to your location
