SOURCE: samsung rear projection sp42w4hpx/xeu
Try plugging the power cable out for the night. If it doesn't solve it there's probably a problem with the power supply that needs professional care. Good luck
SOURCE: my samsung rear projectiontv is showing in 3d
Hi, your convergence circuit has failed, the stk`s and any burnt resistors will have to be changed, if you know how to solder and un-solder proficiently and can use a volt meter it`s do-able if you don`t have this knowledge call a tv tech, generally runs $250 to $350 depending on where you live, call around and ask for estimates to fix the "convergence circuit", if you still have questions e-mail me back, Happy New Year, BMW Rider
SOURCE: samsung rear projicton tv 42 inch aa68-50523a
youll need to have the tv converged...the red being out of line says that
SOURCE: Samsung rear projection TV audio no video
There is a problem on the deflection board (BP94-00501B). I have tried replacing the flyback, both convergence IC's and the horizontal output transistor without any luck. I finally bought the whole board from encompass parts for ~$120. Hope this helps.
SOURCE: hi my samsung 42
For My samsung when the tv wouldn't come on and the standby light started to flash it ended up being the bulb
