Have the HCN4226WX/XAA Samsung. Bought it new at Sears in Aug 2004 for $1400.00. Hasn't been used...
(More)
Have the HCN4226WX/XAA Samsung. Bought it new at Sears in Aug 2004 for $1400.00. Hasn't been used all that much. Just went to put it on, and absolutely nothing happened. No lights flashing, no sound, nothing at all! Totally dead. Had a repair man over, showed the fuse was good, and he couldn't figure it out whatsoever. Charged 90 dollars for the visit, offered to take it to the store that has been here for 30 years, and I was told the repair would cost $400 at least to fix. I don't think it's worth it. Any suggestions?? I will never buy another Samsung product, but I really would like to know if it can be fixed by me with the right part. Can anyone help me out on this? Greatly appreciated.
my hcn4226w won't turn on, the on light comes on and blinks and goes off again. or if button is push...
(More)
MY HCN4226W won't turn on, the on light comes on and blinks and goes off again. or if button is push in it still just blinks also the sound when it shuts off is not make any sound.
when try to switch it on a green lamp sign flashes for a while the goes back to standby and tries to...
(More)
when try to switch it on a green lamp sign flashes for a while the goes back to standby and tries to start again
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
