My computer does not seem to boot up when I switch it on...the lights go on on the LED indicators that suggest the computer is working and there is initially a sound, but the screen remains black. It is as if the computer is starting up but seems to get stuck.
The problem is a damage to the MB by excessive heat produced by Nvidia GPU. The only way to fix this permanently is to take out the MB and reflow the GPU with heat. You can find a video on youtube how to do it. You must take out the piece of gel between GPU and cooling unit and replace it with copper bar or penny made prior 1983 - still made out of copper. Also clean the fan. Use heat transfer paste like arctic cool - not a glue, on both sides of the penny. Install win7. Win7 does not use the coprocessor and will help to ran the notebook cooler. Install speedFan 4.40 - free utility to see what the temp is of your GPU and CPU. If you did good job it will stay around 55C. If your HP notebook is still running check the temp. If the GPU is running 80C or more it will melt the connections on the MB and quit working sooner or later.
Potential source of problems:
1. The Operating System is corrupted
Reinstall OS with WINDOWS installer CD
2. Your Boot Loader is corrupted
3. AC adapter/Battery not working properly
4. RAM is defective
Thanks, Cheers!
It is a laptop and the computer is plugged in correctly
I'm afraid I don't have access to a monitor...it is the vista operating system...my fear is that it is a vista problem
Nothing...the laptop was on hibernate and I came in and attempted to switch it on normally and that is when the problem occured
OK, thank you for your help.
Well I would think that it is a hardware problem, I would take it to a PC repair shop.
If absolutely nothing is show when you power up then it may be a hardware problem. what happened immediately before this problem appeared?
Try hooking it up to a PC monitor if you have access to one. What OS are you trying to run? Have you recently made software changes?
Is the monitor plugged in and turned on? Is it plugged into the correct spot on the pc?
