Hi, this is failed convergence and it is due to a faulty convergence board chip set. simply replacing the convergence board in this set Will fix your issues.
If when you go to Menu then setup and Do Not see convergence then you have open fuse FL231 400ma It is on right side of Flyback Transfomer there is 3 of them in a roll it will be middle Fuse But they do not look like fuses they are small brown rectangular looking. For Part http://servicemanuals.vstore.ca
Is the picture bowed in too. first consult "the fl231 problem" article under the tip and tricks section under my profile. THis MAY be the problem. Otherwise you have a convergence issue. convergence is controled by three cuicit boards in this set. Setting the convergence on this set is tricky. try autoconvergence see how far it gets. let me know and i help you trouble shoot further
Your tv is crt-based and is out of convergence. In other words,
the settings for keeping the Red, Green and Blue images aligned have
drifted and must be reset. This is common with CRT projectors and
CRT rear projection tvs.
Refer to your owners manual for instructions on re-aligning it.
